Thread
Biggest/best brake setup for 15 inch wheels?
21
permalink
12-09-2013, 04:12 AM
RICK LAKE
How much braking do you want??
CSX4910 I started with 15" wheel and tires. The 11" setup for The BFG tires was almost too much when stopping. Lockup was easy to do and flat spot the tires. I added a proportianing valve to help with bias of front to back. This helped on lockup.With poor tires that car still stopped in 115 ft of 60mph. Straight line was optional. I thought the same thing and went to the ERA 12" brake kit and 4 piston setup. THis system is way to much for 15" wheels unless you have an abs system in the car. The braking will put you through the windshield if your lap belts are loose. I went to a Dunlop tire with a softer 260 wear and this helped again with stopping and braking. A have been tracking and auto crossing the car and went to 17" wheel and Pilot tires. I found a balance with the 335 tires on the back. 275 on the front. New down side was the brake pads where for street and not high temp of track abuse. I added the ducting for the fronts and this helped. Serious guys have added fans to cool pads and rotors. I can run 3-4 laps without over heating the pads and rotors too much. I have not added the heat temp paint to the rotors to find out what temp they run hot. This is the real test for setup of braking system. I don't flush the system after every race, some guys have too. Dot 5 brake fluid for high temps.
Tires, Avon are about the best for 15" unless you go to billboards. Have to check out the price on them. Side note, if racing only a couple of older guys where running 15" wheels. Dick smith was one and drifted the car alot. This was his driving style. The newer guys are running 17-19" wheel combos. I have nitto 05 tires with 200 wear. I am happy with them. There is an article about 17" tires in one of the Hot rod or car craft that tested these tires. The test car was a full size boat and weights alot more than a cobra. BFG some how came out on top. Look into these. I know my nittos where 1/2 the price of BFG. Side note, Jack up car after every track run. Billboards get flat spots if left on the ground when hot. IF you are serious get a pyrometer for checking tires temps after a run and learn about alignments and what the car and tires like. I know of Only Morris, Cobra 3170, and Kirkham Having the knowledge to setup a cobra for the best handling. The rest is a learning curve of the driver. Rick L. Ps bring a couple pair of underwear in the beginning.
RICK LAKE
View Public Profile
Find all posts by RICK LAKE
