Old 12-09-2013, 06:44 AM
Mdman352's Avatar
Mdman352 Mdman352 is offline
Cobra Make, Engine: Contemporary-427 stroker
Neutral
Default Just the facts....
If you launch like this off idle....
Using these....
The first to go will be these.....
Then these.....
then these.....
then these....
then the "STRENGHTENED" ones.....
So....unless you have LOTS of these
Really though, the Jag rear was designed for 230 HP and 700 series tires. The design leaves something to be desired (and lots of parts on the track) unless it is used as intended, which is cruising. I have a mild motor (500+/- hp and much more torque. You can spend all kinds of money HOPING it will hold together or you can accept reality and move on to something more suited for the intended purpose. After all, what good is 750+ hp if you can't hook it up and use it??? FYI...I also have a 750 HO Cobra in my garage and it is NOT fun to drive.
