Old 12-09-2013, 07:51 AM
carmine carmine is offline
Cobra Make, Engine: spf 2112 *427 stroker windsor
Hello Motörhead
Need you to check the synchronization between left side bank of carbs and right side bank using synchrometer tool
I know your idle is probably all in synch but what is the synch like at steady 1500 rpm and steady 2000 rpm
If there's difference between left bank and right bank then you have a linkage problem to adjust that is causing engine to run richer on one side bank and fouling that side of plugs at cruising RPMs
Last edited by carmine; 12-09-2013 at 09:52 AM.. Reason: didnt realise he is running webers
