Old 12-14-2013, 09:44 AM
carmine carmine is offline
Cobra Make, Engine: spf 2112 *427 stroker windsor
Hello Ted
Another thing to check.
I see your running a stroker motor.
The crank throw being longer can dip into the oil in pan and whip oil to underside of one side of pistons and cylinder walls under more pressure and oil rings becoming overwhelmed with excesive oil.
The oil pans on most motors calibrated for fill based on stock crank throw.
When running stroker crank that usually means about half to one quart less oil to allow for extra aprox 1/4 crank throw dip in.
