Old 12-15-2013, 05:52 PM
koupe377's Avatar
koupe377 koupe377 is offline
Originally Posted by olddog View Post
Here's my Comp Cams - cam card:
Part # 35-000-8
Engine: FW Ford 351W/302/HO HR/SR
Grind# FW 3316F / 3317F HR110+4
SPC INSTR 1:
SPC INSTR2:
----------------------------Intake Exhaust
Valve Adjustment ----------- HYD --- HYD
Gross Valve Lift ------------ 0.555 -- 0.576
Duration @ .006 Tappet Lift - 287 -- 293
Valve Timing @ 0.050 -- Open ----- Close
Intake ---------------- 12 BTDC -- 44 ABDC
Exhaust -------------- 55 BBDC --- 7 ATDC
These specs are for cam installed @ 106.0 Intake Center Line
---------------------------- Intake --- Exhaust
Duration @ .050 Tappet Lift--- 236 ---- 242
Lobe Lift ------------------- 0.3470 ---0.3600
Lobe Seperation 110
Yea a 114 LS will clean it up some and help with driveability.
Originally Posted by worksalot 2 View Post
Thanks for all of the input. F.y.I. I have the r.p.m. airgap on its way...found a good deal on a used one on ebay. I do appreciate the info on the afr heads. I didn't know they measured flow differently. I will be using the trickflows even though there are better options, because that is what I have. I have not made a decision on the cam yet. I have been busy with interior designing, air and heat options and body work. Thanks for the help...I will keep checking this thread.
Cool you got the airgap. If you have any extra cash in your budget have those tick flows ported. 170's are kind of on the small side for 357 cubes.
