Old 12-17-2013, 05:18 AM
Towmaster's Avatar
Towmaster Towmaster is offline
Yep that's exactly right. You need a low pressure high volume fuel pump from your big fuel tank to the surge tank. Surge tank should be at least 2 litres. You need an overflow from the top of the surge tank back into the big tank. Then your regular fuel pump should feed the engine from the bottom of the surge tank. You can buy pre made ones from perfoance shops / eBay etc.
