Old 12-17-2013, 01:41 PM
stephen low's Avatar
stephen low stephen low is offline
Or Daniel you could bite the bullet and take the tank from the car and have it opened up and properly baffled.
Finding space in the cobra for a second tank, extra pump and then having to re-wire isn't impossible but a right pain in the backside.
In fact I did the reverse and had an in-tank pump fitted into the manufacturers tank that came with the car.
This also has the advantage of keeping the pump noise to a minimum as you'll find the Bosch 044's and the like can be fairly noisy externally to the fuel tank.
Bit of a pain having to dismantle the car, and you have to go through a pretty thorough tank rinsing process over two or three cleans. This is a must to ensure there are no petrol volatiles in the tank to go bang when you start to shower it with sparks and heat.
But I would suggest the easiest fix for your issue.
Slo
slowy
