Old 12-18-2013, 05:56 PM
Towmaster's Avatar
Towmaster Towmaster is offline
Originally Posted by velj1 View Post
thanks for your help guys,
we currently are using a merc fuel pump dont no the exact details of it, but it does produce enough fuel pressure and so on, if i can keep that then run this after it would i be heading in the right direction?
Polished 2 5LT Surge Tank Bosch 044 Fuel Pump Purple Fuel Pump Bracket | eBay
thanks
You need a high volume low pressure fuel pump to feed the surge tank. use the merc one to run from the surge tank to the motor and buy a carter low pressure fuel pump designed to be used with a carby engine to pump the fuel out of your big tank into the surge tank.
