Old 12-21-2013, 12:02 PM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
Originally Posted by BMK View Post
Hi all,
My handbrake/ emergency brake is failing.
I tighten it up and it holds tension on the ratchet. It clicks up around half way and is tight working well.
Then I find after a few uses it releases tension and I can pull it straight back with no tension on the cables.
I am tightening up the bolt/nut under the brake but think there needs to he something to keep the bolt under tension/tight.
Any thoughts...
Hmmm. Drop me an email with your address and we will ship you out a new one. We will need the old one back to see what happened.
Thanks!
kirkhammotorsports at gmail
David
