Old 12-24-2013, 06:59 AM
saturnkk's Avatar
saturnkk saturnkk is offline
Originally Posted by madmaxx View Post
You nailed it!!
"The other things to consider are camshaft choices flat tappet or roller, tight tolerances or loose.
Finally the engines efficiency, tight tolerance lighter viscosity loose tolerance higher viscosity"
Problem is 99% of the guys on this forum have no clue what tolerances their engines were built with and 50% probably don't know if they have flat tappet or roller.
So specific to my stock 1968 Chevy 327 (300hp) with ~120k miles on it, what do you recommend? Stil the Bradd Penn 20/50? I live in Michigan and the car will be driven from about March/April to about October/November.
