Old 12-26-2013, 05:05 PM
Brent Mills's Avatar
Brent Mills Brent Mills is offline
Administrator
Default Need help removing a dowel pin on steering shaft.
Ok, first of all, this is not a Cobra. This is a 1960 Bel Air that I am switching to rack and pinion steering. This requires pulling a lot of the steering components off so that I can put a new modern joint in.
Directions say to just hit it with a punch and hammer which sounds easy enough, but it's not budging. Tried penetrating oil, and heat on the shaft, but still not moving. So, all you experts probably have some magic for me, right?
Thanks much for any help!
