Old 12-27-2013, 08:52 AM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by lippy View Post
While you are working in that area, another little thing I did was to cut out a small patch of vinyl for each side and glue it under each seatbelt anchor. The carpet has cutouts for the anchors but you can still see a small part of the floor panel. With the vinyl glued in it looks really finished.
Lippy - I was going to try and be real careful trimming those holes in the vinyl and was thinking the seat harness plates would cover it pretty well. But, now that I re-call that a lot of other harness makers use eye-bolts there and snap rings for attachment I may just X-cut the holes and push the vinyl inwards towards the tapped holes.
I saw your thread on registration - did you get your engine installed?
Thanks
Dan
