Old 12-27-2013, 04:42 PM
1970 1970 is offline
The fuel feed line is 8mm, pump is Carter rotary under VW fuel tank (front of car). So feed line is "under pressure" (I am assuming somewhere between 4.5 and 6psi), and it is not routed near exhaust or outflow of hot cooling air coming off heads/cylinders. It is routed in channel of body just above RR shock mount, about 12-15" away from closest header pipe.
Timing is 14 deg initital and 32 deg total.
Thanks
