Old 12-31-2013, 09:28 PM
Gofastoldguy's Avatar
Gofastoldguy Gofastoldguy is offline
Cobra Make, Engine: Factory Five Roadster
Originally Posted by mikiec View Post
Do you have the Mustang lower on the car? If not, did you verify that FFR used the Mustang part on their lowers? Did you order one for the other side? How about the upper's?
Mike...b-joint had debris thru the broken boot. Joint opposite was excellent/tight. Uppers checked out fine. Found slightly loose RF wheel bearing. Did alignment check while up in the air. -1deg neg camber, 1/16 toe, 6-8 pos caster. Should be ok Yarnell. BTW uppers and lower arms are the optional ones from FFR. Thx, Bill
