Old 01-01-2014, 04:21 PM
A98Coupe's Avatar
A98Coupe A98Coupe is offline
Cobra Make, Engine: #535 Kirkham 427, 427 Side Oiler
Originally Posted by LMH View Post
Why don't you use offset dowel pins instead?
Thanks Larry,
I have thought about using the offset pins, but they are not a permanent fix for aligning the bellhousing, and I would be faced with trying to remove the existing pins which can be a real pig of a job unless you've got the right tools. So I've decided to go the welded bush route as recommended by Kirkham.
Thanks Grubby,
I agree, I think I have enough dowel pin engagement so will leave the existing pins in place.
Thanks
Stuart
