The cam wasn't replaced at the original rebuild. It was removed and sent to Schneider cams for inspection. Found to be fine at the time. Not sure if the
oil pump is regular or high volume.
The valve guides definitely shouldn't be leaking after 4000 mikes. I'll have more info on the heads in a day or two.
