Thread: Bigger brakes
Old 01-02-2014, 07:11 PM
Rog246 Rog246 is offline
Originally Posted by Rossba View Post
Are you running a VT front end?
Could maybe run VT rear end!
You can get wheels in Jag stud pattern (same as holden I believe)
Ross I'm building a Harrison which uses VT fron stubs (well mine does), & a Skyline R34 rear (same PCD as Falcon) doesn't really matter having different PCD front to rear but I'd like to keep it a bit uniform where I can.
I'll just muck around a bit with bearing sizes to see if I can make it fit, the problem as I see it, will be the stub axle length but a tape measure will sort that out
Rog 246
Harrison #100
