Old 01-04-2014, 04:54 PM
DanEC's Avatar
DanEC DanEC is offline
Lippy - right now it's as ERA adjusted the shocks. If I remember correctly the front is very slightly below the ERA spec of 5-1/4 inch and the rear is about 5-1/2. I think the front is probably a little low per ERA because of my iron heads - versus the more common aluminum head engines that most now use.
ERAChas - I like that photo - is that your car? I think it must be from the color. I think mine needs to go a little lower in the rear and I will probably drop it a little. I'm a little hesitant to drop the front yet until I get a few miles on it. I think I remember you said you had yours set at 4-7/8 inch front and rear.
Thanks
