Old 01-05-2014, 04:59 PM
Towmaster's Avatar
Towmaster Towmaster is offline
Originally Posted by Rossba View Post
My chassis number is 194.
I couldn't get the sway bar on mine because the sump is in the way so would be interested to see what you did with yours.
What shocks you using front and rear?
My assembly book states the superlow which is what I have.
The number at the end of the spring part number stipulates what car they are for so it got me thinking if they changed the specs later and used a off the shelf spring from a different car. I know pedders can do that.
You may have a later chassis than me and/0r run the watts link.
Glad you have yours sorted to a stage that you are happy with.
Don't think our roads are better!
Yep. Mine is chassis 250 which means I think the rear suspension is a bit different. I am not sure when they changed the rear upper mounts for the rear suspension. Yours also doesn't have as much wheel arch flare as mine does which is probably why it is rubbing. Also your body will sit lower over the chassis than mine. Mine is the 'efi' body so it has bigger front and rear flares and the body is 25mm higher on the chassis to allow fitment of the efi manifolds. The front springs will be torana and I think the rear are HQ.
I am off to Japan skiing for 10 days tomorrow so I won't get the chance to pull it apart to have a better look to compare. Send a PM to TUF427, he is more of the 'guru' than I am. He has the same body shape as yours and runs big wheels so he may be of more assistance.
