Old 01-06-2014, 02:59 AM
Default Are you tracking the car?
Mongoose 930 I have both on my ERA car. Here's the thing, If you are going to race the car, you should have both. You are going to find out that when the fuel pressure gauges starts to bounce or vary you are sucking air through the pickups. I have 2 255 pumps in the tank and can't race below 1/3 of a tank from pulling "Gs" on turns. My pressure gauge is on my fuel regulator under the hood. DON'T run any lines into the car for fuel!!. The line breaks and you get a bath or worse, cooked. Copper, plastic, steel, and aircraft line all break down over time and will leak. The reason you have problems with the gas gauge reading correctly is not enough baffles in the tank. If you are looking for a better sign from the tank, you need more baffles, or change to a different sender in the tank. The arm with a float on the end is poor. This is ment for getting into the car and checking level. IF your fillup is a straight into the tank then use the old stick method. I don't know what size the motor is but racing you are looking at 1-4 gallons per lap racing depending size of track. Normal driving from 8-20 mpg. Good luck Rick L.
