Old 01-06-2014, 03:55 PM
wemooz wemooz is offline
Cobra Make, Engine: ERA 290, 428CJ
Default Wiring diagram
My wiring diagram shows that the brake warning light was connected to the now discarded brake warning switch by a wire labeled "P", which I assume is in the bundled wires that used to connect to the old warning switch. It seems to me that if I could locate this "P" wire, I could run a wire from it to the hot lead to the fan, which is coincidentally labeled "P" also, and which is between the fan and the fan relay. Both of these points are on the engine side of the firewall and maybe not so far from each other. If this were done, the indicator bulb would be connected in parallel with the fan. If this might work, how could I locate the "P" lead from the brake warning light?
