Thread: up & running
  #22 (permalink)
Old 01-08-2014, 02:25 AM
renovationinnov's Avatar
renovationinnov renovationinnov is offline
Cobra Make, Engine: venom motorsports /ls1 auto
well today the cobra went to the Burpengary transmissions
open the pan & low & behold the problem hit them right in the face
the shifter shaft & rooster plate was loose & in upside down & the selector shaft was fitted back to front so
they checked it all out & found only those 2 things the problems
thanks side show I watched them test the box & ran it on a scanner & checked all codes & no faults found
so around the block we went wooo & the looks we got
if any one in Brisbane north want a gear box place Burpengary transmission are the real deal
all the that was a cost of $ 220.00 cash now to get the thing up to temp to check the gauges all work & get the tacho working then all the insulation to be fitted
ROB
not all your babies are your children
