Thread: up & running
Old 01-08-2014, 07:55 PM
renovationinnov's Avatar
renovationinnov renovationinnov is offline
Cobra Make, Engine: venom motorsports /ls1 auto
side show
rang the ecu tuner
he said that I need a 1k ohm resistor in line from pulse wire to bridge to feed wire
as the signal is needing boost
he also said as you did that most cheap tacho don't need this
I hope this is right & are the resistor directional eq ;; 1 side to power only
rob
not all your babies are your children
