Old 01-12-2014, 08:32 PM
byroncobra's Avatar
byroncobra byroncobra is offline
Jim you're a classic with some of your solutions.....you're pool must have a lot of stuff on the bottom
I've tested the TFI and it's within specs and the hall sensor is triggering PIP signal with an LED test light.
SBFTech.com TFI Module/Hall Sensor Testing Procedure
If I kick it over it occasionally starts for 2-3 seconds then dies. I pulled a plug and i can see it sparking the same.
I'll go and check the coil i spose but a can't be that surely given its brand new
One thing that i thought was odd was that the fuel pump primes as usual at key-on, it normally pressures up and then turns off. However, it is cycling on and off....bit wierd
Greg
