Thread: Wacko qusetion
  #25 (permalink)
Old 01-14-2014, 10:06 AM
Car Nut Car Nut is offline
Originally Posted by Danr55 View Post
The question indicates that the point A moved 1/8" from line A B C. In order to be 1/8" from the line, it must be in a perpendicular direction. If you move 1/8" in anything other than 90 degrees direction , the resultant distance from line A B C to the relocated point A will be less than 1/8".
I think more correctly the vector length of 1/8 inch moved, it does not say which direction and there are 360 degrees of movement that can be considered. The question indicates point A is moved 1/8 inch, (from its original point, not line ABC) as quoted "If I move point A 1/8" to the left. How much do I have to move point B to maintain a straight line to point C?"
There is not enough information to satisfy the question. That is why it is (as in the thread title) a wacko question. You cannot solve it with exactitude.
_____________________
