Old 01-14-2014, 07:10 PM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
Double check your firing order if you haven't already, just to be certain. I ran into a problem a few years back with plug wires. I was running a Mallory electronic distributor and coil. I bought some nice plug wire holders and a new set of blue max plug wires. Installed the looms and made up the wires. Car would not run...if I could get it to start it ran like crap. Swapped and put the old wires back on...ran fine. Just a problem I experienced.
Almost sounds like a bad ground possibly as well. Seen that do really funny things in the past.
Gene
" If it wont break em loose in 3rd gear, it aint enough power "
