Thread: Goodbye Kansas
Old 01-17-2014, 07:25 AM
DanEC's Avatar
DanEC DanEC is offline
I was just under the dash of mine working on my charging problem - what I discussed above should work if Bob's solution doesn't fully meet your needs. I think the only negative drawback is that the further from that dash support that you position the wheel, the less rigidly mounted the steering column is going to feel. My column is down as low as it can go (#782) and there is plenty of slot left in the dash panel to go lower if you do so.
