Old 01-17-2014, 08:42 AM
strictlypersonl strictlypersonl is offline
8. Continuity of G/R wire at VR plug to dash light - Yes. Oddly, I have the parallel resistor wired in place and when I disconnected one wire from the light I only had continuity through one of the two leads. It seems like it should have circled through the resistor to the other side with the disconnected lead. May be nothing.
I'm not sure I that understand your description, but if you actually have an LED for the light, it will act like a diode.
