Old 03-30-2002, 10:16 PM
niles niles is offline
Cobra Make, Engine: Hunter #28; 396 Cleveland stroker; more than 495 HP; TKO 5 speed
Default 351C
Keith:
checking compression; is like your blood presuure; it's the most important test you can make.
It's a guage that screws into your plug holes and you turn the motor over with the starter and measure the psi of each cylinder. You could be dragging around a dead cylinder; that would explain your low dyno reading.
Should be within 10 psi of each other; your engine should be around175 psi; (any good values from people with similar engines?
If you need more info/detail - email me
gn
