Old 01-19-2014, 03:54 AM
Default It's for jackup cars
Guys you see no one under the car. It's just to keep it off the ground or raise it to put jack stands under. If you don't have electric or a generator in the trailer, it's not going to work. Both sides are hooked into 1 line from the controller, so pressure will be even to lift at the same rate. Change tires on this setup quick, see no problem. Any major work like trans or clutch replacement, I want jack stands. If money is no problem, goto the air lift like F1 cars. Other thing, they are picking up a stripped out honda not a BB cobra. Like anything, looks great for certain applications. Rick l.
