  #143 (permalink)
Old 01-20-2014, 06:50 AM
601HP 601HP is offline
Originally Posted by lippy View Post
David,
Which solid rollers do you have? How often do you check the lash, and has it ever required adjustment?
Lippy
Lippy,
Mine are the Crower EnduraMax. They are bushed rather than having needle bearings.
I run through the lash at 1,000 to 1,500 miles for general maintenance, however they'd probably go much farther between adjustment.
I inspect and adjust at that frequency because of a short discussion I had with Blykins, on another site. He had mentioned cam "lobe intensity" and I didn't know what the heck that meant. After he explained the term, it was evident my cam has a numeric lobe intensity that he considers to be more harsh on the springs. Subsequently I do more frequent under the valve cover inspections.
David
