Old 01-20-2014, 03:07 PM
saltshaker saltshaker is offline
Cobra Make, Engine: Contemporary Cobra
Default Flow
Are you reading the 4 center barrels? That you should be able to even out.
The four outer barrels are usually off a little.
Second question, are your slave carbs adjusted to open with the main? That can throw the slave carbs off on each side.
Who's linkage are you using?
Jon
