  #29 (permalink)
Old 01-20-2014, 07:44 PM
Barry_R Barry_R is offline
Actually at 1.27/cube your torque number seems pretty rational for a strong build, although your power peak RPM seems low compared to the torque peak. I usually see +/-1500 RPM between them - your's is a comparatively narrow 1000 - you might have more "in the bank" if you can find out why it stopped there. Or you may have something in the combination stunting the lower RPM torque or forcing the curve upward. I sometimes see really brutal torque "bumps" from IR setups when they hit the resonant tuning length.
I have, however, seen some FE dyno data posted around the net with torque at 1.5 or 1.6 per cube and that simply ain't right. It might happen in a Super Stock or dead serious race package with tons of compression and cam - but not in the land of pump premium and hydraulic rollers.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
