Originally Posted by jhirasak
jonalley,
"........... Upon later query to the Weber tuning forum, it was suggested that I should have slightly twisted the shaft to equalize the airflow on a single carb so both throats would flow the same value. In hindsight, I think that this would have been preferable to drilling the butterflys.
I would recommend that you take all of the Webers off the car and build you a test fixture........"
A slight twisting of the throttle shaft is the preferred method of fixing your issue. This problem is not uncommon and will reoccur . When it does, the drilled holes in the butterfly are going to have to be re-filled and start over. Not a good thing.
I don't see the need to remove the carbs and build a test fixture. Just lightly bend the shafts and be done with it.
Z
