  #114 (permalink)
Old 01-22-2014, 06:39 PM
Paintwerks Paintwerks is offline
Cobra Make, Engine: Pace 427SC. LSA Supercharged with 6sp TR-6060 trans.
Originally Posted by gjkrv8 View Post
That is a very awesome engine. I am jealous. cheers Gregg
P.S. There were some quite interesting articles in the web about the challenges HSV had with ensuring they had enough frontal area for cooling inlets etc, so that GM would honour the warranty etc. Not sure if this is an issue for your Cobra or not.
Thanks Gregg.
I read about that too. The LSA uses a Magnussen MP1900 supercharger on it which my friend is also running in his E3 HSV R8. That thing has made 385kw atw for the last 12 months with no issues so it is tuned to make more power than a stock VF GTS.
So apart from the water-to-air IC/heat exchanger versus the air-to-air IC on the aftermarket Magnussen MP1900, I'm hopeful that I can get a large enough radiator in there along with a custom sized heat exchanger to sit where the oil cooler would normally sit.
It's possible I may not need an oil cooler given than the car is so light, but if I do, I should be able to mount one (or two) 9 row oil coolers in the air nostrils either side of the main mouth opening.
www.paintwerks.com.au
