Old 01-25-2014, 06:47 AM
madmaxx madmaxx is offline
The reason your caps don't last is you need to bend up the rotor tab to ensure it make CONTACT with the rotor button. If not it arcs and eats both away.
Always grab your distributor and twist to see if the hold down has deformed allowing it to turn. The better clamps don't deform.
Originally Posted by Mark Brye View Post
Check all fasteners once a year. Change brake and clutch fluid every year. I always have to change my MSD cap and rotor every year also as they don't seem to last. I would also take wheels off once a year even if you don't need to so your spinners don't weld them selves to the hub.
