Old 01-26-2014, 07:20 AM
mickmate's Avatar
mickmate mickmate is offline
Dan just an observation, with the large offset done to the same pedal arm you have lost a lot of length on your pedal arm which is leverage or in this case pedal ratio. I have changed several clutch set ups by 1/16" at a time on the bores to give just what you need to release and no more. It did make the pedal noticeably lighter. You can get pretty close mathematically measuring it all. Stroke at clutch and at pedal, pedal ratio, bore sizes.
mickmate
http://www.actoncustom.com/
