Old 01-27-2014, 02:52 PM
52chevyred's Avatar
52chevyred 52chevyred is offline
Cobra Make, Engine: Street Beasts 302 HO
BoatBuilder3: there are plenty of SB folks on Club Cobra, which can help with questions. I suggest you check out Okieguys Main Welcome Page They have pictures of their build from start to finish. I don't suggest the "adding 1" metal to the top of the frame, like they did: just complicated a lot of things. The rest was good & was helpful to me. Also "Fast Cars & Guitars" on YouTube has great video clips of his build from start to finish.
You "probably" will find some problems that make you scratch your head, but one thing I learned in an over four year build: if ONE (SB) has a problem, they ALL have the same problem, because "they" never changed anything at the factory. It's the "solution" you chose that makes the difference.
One example for me: the back of the car was "high" (not touching the frame, about an inch). After cutting the trunk out, lowering & re-Glassing, about a week later, "Pete" with Hot Cars posted where he cut a small "pie shape" on the frame: problem solved. That tip, a week earlier would have saved me several thousand dollars.
I put mine in a lot of car shows now and have won "Best of Show", several times. You may get "discouraged" at times, but there will be a solution for your problems. Good Luck!
52chevyred
