Old 03-31-2002, 05:53 PM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
When you check the compression, do it with the engine hot, all the plugs out at the same time, and the carb. held wide open. Use something to hold the carb. open so you don't wash the cylinders down with the gas from the accelerator pump every time you open the carb.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
