Old 01-28-2014, 05:06 PM
Dimis's Avatar
Dimis Dimis is offline
Originally Posted by Paintwerks View Post
Sambo....mate, I have wondered about this myself. I don't have an answer for you...guess I'll find out! T.L. says that his Cobra makes 417kw atw so perhaps he can chime in about the general drive-ability.
It has more to do with the power curve than the peak numbers.
Assuming all else is equal - If those numbers are down low in the rev range, then your cooking those tires with every twitch of your toe.
If however those numbers are higher in the rev range then you'll get away with it if you drive softly in the lower rpm range.
ECU management of power delivery can help here.
Mind you this is easily said in theory and something else to achieve in practice.
Thems my humble thoughts.
