01-29-2014, 03:57 PM
RI
Cobra Make, Engine: Fordstroker 408w custom solid roller-Craft ported Brodix 17*heads-CFM ported Vic Jr. intake-1 3/4 primaries- 575hp-TKO-600RR Liberty upgrade- -Moser 8.8 trutrac-McLeod Street Extreme--QA-1-Wilwood brakes, Classic Chambered 3" Cobrapacks, Avon's
The problem with the TOB slightly touching the fingers is that it can be noisy. On my super street pro setup I had to keep it off the fingers. McLeod reccomended to have it off the fingers. Make sure you get the pivot ball height adjustment right so the fork contacts the fingers at the correct angle. Pedal stop position and the correct Master and slave cylinders should complete the correct movement and give you the correct gap .040
Lou
