Old 01-29-2014, 04:20 PM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by kevins2 View Post
Hi Lippy,
I adjusted mine exactly as you described and it starts to engage about 1 1/2 to 2" off the floor, which feels good to me.
I played around with mine a little Monday and it's starting to engage at around 3 inches off the back of the footbox, maybe even a little more. My pedal is at 8 inches with about 1 inch of play so it's all in and all out over a 4 inch pedal stroke. So it kind of depends on where you like the clutch action to be and how high you want the clutch pedal to rest.
Lippy - what size clutch master cylinder did they provide you with? I started out with a 3/4 inch but it made for a long throw to get full disengagement. I went to 7/8 to shorten it up some (feels about right for me now) but it increased the pedal pressure some which is a negative. But that is another element in the clutch system that you can play around with to get it to your satisfaction.
Just noticed above that you said you have a dual disc clutch. That may be another whole ball game so my comments may have no bearing.
