It appears in the end there is no advantage to link bar style unless you are forced to use them do to a retrofit or block is not set up for the dog bone style.
Bottom line for a hydraulic roller the stock ford racing lifter is as good as it gets as long as you can use the dog bone style retainer.
I have had good luck with the ford racing lifters even with spring pressures in excess of 400lbs.
