Old 02-01-2014, 11:12 PM
gary osborne gary osborne is offline
Cobra Make, Engine: Superformance 514 ci
Ward….The lugs are simply out of alignment. Don’t mess with the wheels. Get the pins properly aligned. You will probably need a alignment template (tool) to do it. You can get one from Trigo for a few bucks. You will use it over and over so the investment is worth while. The tiniest misalignment (almost imperceptible) will make it virtually impossible to get the wheels on and off. There is very little tolerance. But it is easy to take care of with the right tools. Once you have the alignment tool, you can just tap the pins a tiny bit until you get them properly aligned. It is not scientific….just takes a little patience.
Uncle Fester - Yes I REALLY did say that
