  #36 (permalink)
Old 02-02-2014, 05:02 PM
patrickt patrickt is offline
^^^Why a union in the master to slave line?
You see that chunk of aluminum that is between the bracket that holds the slave and the block? When that chunk of aluminum is used to move the slave bracket back towards the front of the car, and inwards, then the preferred method is to union the pieces between the slave and master. That chunk of aluminum is actually a rather carefully milled spacer, drilled with the appropriate holes. Some builds need them, some don't.
