  #84 (permalink)
Old 02-06-2014, 11:10 PM
Dominik's Avatar
Dominik Dominik is offline
A spacer plate which will give you that gap, yes that might be your solution. Like the ones between block and bellhousing for the FE engines. Bur for trying, use 2 shims under each bellhousing bolt?
Can your disks be reversed, resulting in too much height? Isn't the one side of the disk assembly tapered where the transmission input shaft sits and the other side flat? They should be marked "towards engine" or something.
If I don't respond anymore, that's because I can't log in
