Old 02-07-2014, 11:25 AM
maurice19 maurice19 is offline
Cobra Make, Engine: owned Kirkham for 11 years
Lippy,
I have been following your situation with the clutch.
Do you have a shortened input shaft, and if so,were the splines also cut longer to make up for the shorter travel.
I had to get a different input shaft with longer splines,so that the shaft would insert all the way into the pilot bearing. If the splines aren`t lengthened a like amount, the input shaft can bottom out on the clutch disc.
My original Ram with tko 600 and shortened shaft was ok.
My McLeod replacement needed more spline length
Just a thought, as I haven`t seen it mentioned before.
Maurice
Last edited by maurice19; 02-07-2014 at 11:58 AM.. Reason: changed pressure plate to clutch disc
