Old 02-09-2014, 11:20 AM
kevins2's Avatar
kevins2 kevins2 is offline
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
Lippy,
Since I just recently installed mine, I'll chime in. My primaries are ceramic coated and I have stainless steel sidepipes. I used Walker's Acousti-seal - it will serve as a lubricant but will obviously dry if you take too long. Definitely a two person job as Bob said. Be sure to cover the hanger bracket on the back of the sidepipe with some thick rags in case they contact your paint. I used a 2 1/2 lb. plastic dead blow hammer and with one person wiggling the pipe around, "persuaded" the pipes on with the hammer and also pushing and wiggling the collector end. I don't think I could have gotten them on by myself. About two weeks later, I had to remove one to enlarge the body opening a bit (you may have seen photos of that on my thread). The Walker's cleaned off pretty easily and the pipe went on much easier the second time - still had a second person helping but it was considerably easier.
Kevin
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
