Old 02-11-2014, 08:52 PM
WardL's Avatar
WardL WardL is offline
Cobra Make, Engine: SPF #2608, Roush 427SR T-W
This is an old thread but was most relevant posting to my search on my topic. Here is my problem: Original wheels fit fine, my "new" racing wheels don't fit on the rear. I get a Trigo pin alignment tool and it points out my pins are out of alignment. Trigo says slight taps with a hammer on the pin should bring them into alignment. I can get two pins in alignment (with all the other pins off). I put the third pin on and the alignment tool binds up and won't go on. How do you know which way to gently tap the pin? What if the pin is bent in, towards the hub? You can't tap on the pin from that angle! Any suggestions on how to align my drive pins would help. They can't be that far out because the original wheels fit fine@!
