Old 02-14-2014, 03:57 PM
jolsen42's Avatar
jolsen42 jolsen42 is offline
Well, it might improperly - if the cap has a SB firing order molded into it (as the OP said his has) and someone not knowing any better tries to wire his FE to match it. I don't see where anyone alleged that the engine's proper firing order is established by the cap.
You did.
Probably has a small block distributor cap on it.
There is no small block specific dist.cap. They are all the same. The op never said the firing order was molded into the cap. He said it was marked. I would think most likely with a sharpie. Anyway, I think we've sufficiently covered this.
John O
jjo42
